Old 12-16-2019, 10:56 AM
redmt redmt is offline
Originally Posted by hauss View Post
I could be wrong but, back in high school auto class, many years back, I was told add oil to the cylinder and if your compression goes up, it is your rings.Not sure if this will help in your situation ,but I would give it a try.
You are right but adding oil to a cylinder will always make the compression on a good cylinder rise. It's when it doesn't rise there's a problem. Plus if you don't clear the oil out afterwards it has the strong potential for make a REALLY loud noise when you fire it up. It's called hydro locking.
