Originally Posted by STEVE-O
Does the plastidip run at all after it is sprayed or just do light multiple coats? The masking tape is removed right after the last coat?
It sort of melts into the previous coat. As long as you don't put it on way too heavy, it does not run. I tested it on a door that I was working on before spraying on my cobra, and I followed the instructions on the can and put five coats on. Right after spraying the last coat, I peeled off the tape pulling away from the paint.
When you peel it off, it's almost like the black Nitrile gloves.
