Originally Posted by jeffgrice
Regarding your question on the using the BD gas tank it depends if you ordered the optional aluminum tank with topside fuel pump. If so that's the trick. If you accepted the stock plastic tank you'll need to R&R with an aluminum tank to support the FI system.
Jeff
I'm not sure that's true. You could be right, though. I saw a picture of a plastic tank on here recently. It seems it had the outline molded in to the top to match the Tanks pump. All you had to do was cut and drill as marked. Maybe that was only that tank, as it's the only one I've ever seen.
