  #34 (permalink)
Old 12-29-2019, 12:24 PM
1795's Avatar
1795 1795 is offline
When you take the manifold off again from the saran wrap, place the manifold n a flat surface and see if it rocks back and forth or from side to side. I was having trouble with into manifold gaskets leaking and it turned out that the intake manifold was a bad casting and it was not flat; there was a slight twist to it. Ordered a new intake manifold and the problem was solved.
