Originally Posted by spdbrake
I think the newer cars won't need the Heim joint as the outer shaft support tube extends to 5 or so inches from the upper universal. Ref Fred's #2 & #4 pic above.
My early car the outer support tube terminates approx 18" from the upper universal. I did slide the new Splined (cut to 21") shaft up past the Outer support shaft mount.
Shot of my upper support tube and the skinny inner steering shaft hanging in space.
Ah, now it makes sense. I was wondering why you said that you slid the insert so far up. Mine would only go about 12" max easily and is the same as Fred's. I cut it at 6". Many thanks for sharing the technique and parts list! Great mod!
