I know little about superformance clutches, but you should ask what type of clutch they installed in the car. Depending on design, which I will not elaborate upon, they can be quick to engage.
On original Cobras, the early cars had TWO holes in the clutch pedal. Positioning the rod into the lower hole greatly reduced the pedal pressure. So, you might investigate the angle of attack of the clutch rod. It may be attached too high on the pedal. bob
