Old 01-17-2020, 12:36 PM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Mounts
I take it you are referring to those little plates that were taped on to one end. I pretty much discounted them. I will figure out something for the brackets. I am pretty pleased with the quality of the set up. I will run a 12v lead with a reset breaker off the backside off the battery cut off to a relay that will be activated by the ignition switch. From there through a toggle with a blue LED indicator to the fans. I don't want them running unless I switch them on.
Fred
