If "bogart" means copy it, all I did was to scale it from Patrick's setup where he shows the footrest with the tape measure, and also scale it from the printed picture which I found somewhere here on CC.
Alum. sheet is 16g/1.6mm thick.
Screws (4) are M5 button socket head, screwed into tapped holes in the footbox, and Nylocs as well on the engine side.
Patrick's suggestions on "Z" location (ie fore/aft relationship to the clutch pedal) helped shortcut the trial-fit procedure too.
Glen
