I see as the kit instructions are for the older peg drive adapters I doubt it will work for your application.
Granted you could measure the disc hat bore and offset requirements and get Willwood make or sell you a set of hats. Your current calipers look to be the stock E36 units so at least those are not an issue.
But then your on the path. And modifying an already expensive kit with no ability to get a refund.
It may be easier to just return it and get a de-bugged kit from Iconic once its available.
