Old 02-24-2020, 10:40 AM
Igofastr's Avatar
Igofastr Igofastr is offline
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Make sure that you register it as a car from before 1965, and or use a block from before that date...otherwise you will need to use a pcv, which complicates the use of webers. It can be done, but it's a bit of a pain. If you need help, I built a set of spacers with vacuum lines to go under the webers along with a cheap Chinese valve cover with a pcv.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
