Old 02-26-2020, 05:45 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
If the fan is weak, you may have issues AT IDLE. Once you are rolling, the radiator gets plenty of air. You can look the mfrs specs, but typically fans that draw less than 15 amps may not have enough cfm at about 0.8” vacuum.
A good shroud is important as well.
I’m sure we’ll meet soon enough.
Good luck, be safe.
Mark
