  #21 (permalink)
Old 02-28-2020, 03:51 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by CompClassics View Post
The PCV is not an issue, put a PCV valve it one of the valve covers and run a hose to one of the Weber velocity stacks. You may want to purchase an extra velocity stack as the hose will have to attach to it. We used a threaded fitting for the velocity stack fitting but you can figure out what works best for you. After the inspection you can change everything back to the way you had it.
Depending on your inspector things can get out of hand or they may let you by on some requirements. You also mayy need a brake and light inspection.
That's not how to plumb for PCV.
Fresh filtered air needs to enter the crankcase, either via a filtered oil cap, or hose to a carb filter base. The other side of the engine then needs a PCV plumbed to manifold vacuum.
On a Webered V8, these needs to be plumbed to ALL inlet runners, either via a spacer under each carb, or individual feeds drilled and tapped into each runner. I have mine plumbed under the manifold.
Gary
Gary
