Zderf Said, "I'll send you an email with digital image of my set up. The top of the
oil filter mount housing should have arrows pointing towards the filter and away from the filter. You have two extra ports, one filtered, and one unfiltered. The filtered can used used for a preoiler, and unfiltered is often used for an
oil pressure sender.
Hope the image helps.
Zderf"
May I get a copy of this if you have it available? Also, I looked at my dual filter mount. one entire side appears to be for inlet to the filters and one entire side is connected to the center of both filters for exit. How would you hook up the
oil pressure sender?
