Old 03-15-2020, 05:50 PM
andig andig is offline
Cobra Make, Engine: CSX6128 with Shelby 468FE
Originally Posted by jhv48 View Post
Sounds like vapor lock. Boiling fuel in the float bowls. Does the carb have a spacer between it and the intake manifold?
If you have a switch to turn on the radiator fan, (the one on the back side of the radiator) try leaving the fan on while driving in stop and go traffic and see if that helps.
Try the simple things first. Since it runs great until heat builds up, that should be the culprit. And with less than 1,000 miles in 4 years, my guess is the previous owner never drove it long enough for the problem to surface.
Thanks and there isn’t a spacer so could be worth getting one. Also, removed the air cleaner and was surprised to see that two of the barrels were coated with carbon but two were clean - not sure if that points to anything in particular as the cause though.
