Old 03-26-2020, 12:00 AM
saki302's Avatar
saki302 saki302 is offline
Cobra Make, Engine: Superformance Mk3, Roush 427
Default Oil pan gasket advice/choice (351W block)
Hey Guys!
I'm still down to my last oil leak on the car- Roush 427R motor with 38K miles.
I already changed the oil pan gasket once to a 1pc blue rubber fel pro.. but it turns out my oil pan flange is the dimpled type, which I was told does not like the 1pc rubber gaskets
Can anyone recommend a good 4 piece oil pan gasket or even a 1 piece that works to SEAL it once and for all?
BTW, it does leak in a slightly different spot than before, but it still leaks
Any tips for installing a 4pc gasket? The 1pc went in pretty easy with those plastic threaded guide stud things that came with the gasket.
Thanks!
-Dave
