03-26-2020, 10:48 AM
IN
Originally Posted by joyridin'
I have a unit from a Saturn in my car with an adjustable knob to adjust how much assist you want. Really works great. When you are in tight areas, you crank up the assist and you can whip it around with one finger. I have 10" tires on the front. When you are going down the highway or taking those nice curves, you basically crank the assist to zero. This unit mounts between the column and rack. Not sure if it would work on a BDR or not.
That sounds like what I had in the 7. It worked well but no feel whatsoever.
