Old 03-28-2020, 12:41 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Check the water level of your battery, if you are cooking it, the level should be going down, if it's down add and then see if it goes down or remains the same. BE VERY CAREFUL around the battery, if you are cooking it, it will be putting out a lot of explosive gas and a spark will set it off. Saw one blow the top of the battery off sending acid all over, be care full.
BillK
