Originally Posted by Mike I
You don't mention the type of battery installed in your car. If it's lead acid, then any of the units previously mentioned will do fine. If you have an AGM type battery, you'll need something like the BatteryMINDer Model 2012-AGM, which will cost a bit more.
Battery Tender Plus is compatible with AGM and gel.
