Old 06-11-2002, 06:58 PM
John 550 John 550 is offline
Cobra Make, Engine: ERA / nascar side oiler
Trigo / addaptors are held on with threaded pins ,when removed your left with a typical rotor . The rims for "your car " are back cut .There could be an issue if you go wider . Don't drop the clutch out of fist gear , ERAs hook up way to fast ( having twisted off a few axles I know first hand ) other than that , you should not have a problem . What "these cars "lack in turns, shure make up with tork .
