My quickfuel dp has an externally adjustable secondary idle air screw located on the right side toward the rear. It’s a vertical screw about 3/4 inch long with a spring around it. Screwing it in (clockwise) opens the secondary blades. No need to remove the carb. Easily adjusted externally.
Jim
