Old 04-09-2020, 10:20 PM
fastd's Avatar
fastd fastd is offline
Cobra Make, Engine: ERA FIA, 351W
My efi is the carb (throttle body) type. I think the efi stack type look great. Switch to efi! My holley set up permits electronic distributor that allows adjustment of the timing through the interface which helped with hot cranking. The efi helps offset several problems I had with carbs including fuel boil, vapor lock, hot start, flooding.
I think it’s the 6060 - I’ll check that in the morning.
