Old 04-09-2020, 10:25 PM
olddog olddog is offline
How many rpm are you building the engine to peak the Hp? Or more precisely, how many rpm will be you shift point? It matters.
The TKO 600 (which I have one), does not shift as good as it should above 6500 rpm. Some say a little less. There are experts who can modify the transmission to shift much better and at much higher rpm. A used TKO sent in to be modified, would give you a better than new unit for about the same price as new. Maybe less, if you get the right deal.
I suspect every transmission out there has something less than ideal, under some conditions. I cannot tell you specifics.
The Tremec six speeds may be a bit too long to fit in some Cobras, especially if a live axle is used.
You might want to expand your knowledge quest into some of these other areas.
Good luck.
