  #34 (permalink)
Old 04-11-2020, 03:19 AM
Unique427 Unique427 is offline
Originally Posted by Anthony View Post
Well, you can get an all aluminum toploader.
I've got a 1-3/8" input aluminum Toploader from David Kee (DKT).
It's about 25 lbs. lighter then the cast iron unit.
Also replaced the plastic Hurst shifter bushings with machined tool steel
units from Paul Cangialosi at 5speeds.com. These have kept the shift
alignment perfect with zero slop. Machined with the exact same
dimensions as Hurst bushings and will not crack or deform.
