Old 04-11-2020, 04:33 AM
AC Ventura2 AC Ventura2 is offline
Hi Gary. Had to re register as AC Ventura2 to enable sign in.
Thanks for the carb info. I will check under load vacuum, by taping the gauge to the screen, but can’t drive the car as yet due to severe lockdown here. . In the meantime I’ve ordered a 4.5 and 8.5PV and a selection of primary jets no’s between 70 and 60. As they at low cost, I’m prepared to take a chance on this.
If by mixture screws you mean the four corner idles, they are all about 5/8 of a turn out from bottom. This is where I found the max vac. Any further in and it drops again.
If you mean the
