  #47 (permalink)
Old 04-12-2020, 06:17 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Originally Posted by fastd View Post
What do carbs have to do with it?
Not enough adjustability on the carbs to make it run correctly when in higher gears. I could cruise down the highway in 6th, but it would buck. A lot depends on your cam also. 1900 RPM is way below the range of most camshafts. You can adjust EFI enough to make it work.
