Hi, even though I installed a coyote I still needed to use the 22.5" from the top front cross bar. The photo that I have included is from Joe at A&C. Needed these dimensions to build a mock up since I didn't have the body. I the photo doesn't appear check my album.
The reason to use the 22.5" to the middle of the passenger side header tubes is to get the correct location for the exit point. for both sides. This is how A&C's has you set the engine mounts position. In fact the headers you have from Shell Valley seem better a better fit that A&C's. The second photo I have included is from a build I got off the net. Hope this helps. John
