Old 04-13-2020, 12:53 PM
peterpjb's Avatar
peterpjb peterpjb is offline
if you build a replica of 289 ‘FIA’, the specs for the engine are described in the FIA homologation No. 115, you should use a fivebolt C3 or C4 289 block with the matching cast iron heads, standard bore and standard stroke, and Weber 48 IDA...
