After getting the bushing bores cleaned out (old rubber and oxidation), I reversed the removal process and installed the new bushings. All went well and the suspension should be considerably stiffer thanks to the new poly bushings.
A quick Public Service Announcement - if you have never used polyurethane bushing grease, realize that is is the gooiest, stickiest, get-on-everything-within-a-10-foot-radius stuff that you will ever use.
