Bulldog,
If you go to the poly bushings, I'd recommend the black ones.
Some years ago (caveat: things may have changed!) the red ones didn't have as much graphite lube built into them, and would develop annoying squeaks after they've been there a while. The black ones definitely resisted squeaking better. Internet says "maybe" after some searching.
Either of these bushings will usually give superior control over the moving parts - i.e., less flex - and should improve the handling a bit.
Tom
