Old 04-24-2020, 09:28 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Whenever I get a vehicle with a shaft seal leak, I check the shaft movement.
Many times, excessive shaft movement inside a trans bush, or pinion bearings, is the cause of the leak.
Poor driveshaft design could be wearing the trans output shaft rear bush and hence the oil leak.
Gary
