Old 04-25-2020, 12:18 PM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Tom, thanks for the "heads up" on the injectors and pan. Problem is my current 38lb injectors are matched to my MAF meter. Will take a look.
I found a solution for my trans/bell housing. I feel a little stupid at this point. I was looking at the front shaft snout and discovered that it had a spacer ring on it. Had to pry a bit to get it off but it now fits perfect with the stock housing!
Next I will await the new longer pushrods and see what choices for the injectors so I can button up the motor and get the engine compartment ready to reinstall the engine/trans.
Thom
