Fluid volume
With the smaller diameter brake master cylinder your displacing a smaller amount of fluid for the same pedal travel ... so if you need say 100cc to fill the front calipers then you will need to push a 5/8 cylinder through a longer stroke than you would a 7/8 cylinder.
Cruising in 5th
