Old 04-29-2020, 10:03 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
It could still be dragging a little and not fully releasing. Clutch travel between the car starting to move and peddle fully up? Also, if cable, it could be stretched, if hydraulic, air in the line or low on fluid.
Fluid level in transmission?
Just throwing out suggestions.
If none of the easy stuff, it almost sounds like internal shift linkage loose or broken.
