What are you guys doing?
Just thought I'd see how everyone is doing out there. While we're stuck at home it's an opportunity to catch up on the little things (and big things) that are so easy to put off. Myself, I've done a couple for updates to my roadster. Removed all the carpet and insulation and replaced with newer and better materials. I made a couple of wiring changes and di some general cleaning up. I also removed the old Mass-Flo EFI and installed a new Edelbrock Pro Flow system. What a difference! No big deal to set the base program, just a few questions on the pad to answer, then start it up. Ideled and checked the timing, drove as advised and have only had to adjust the fan on-off limits. Maybe this Corona thing will go away before too long and we can get back to normal.
