Originally Posted by FredG
Talk about complicating something.....When I purchased the car the previous owner told me the 427r was a bit finicky in that it didn't like lower RPM's specifically under 2k but past that the power comes on very quickly. I think it took all of about 15 min to adjust my driving habits and shift points. Problem solved.....nothing else need.
Fred
Yes. The only issue I have had regarding a cam, is with an all aluminum engine, and solid roller, that do to thermal expansion, I had to try to adjust the lash so tight when cold, I had some issues starting and running the engine until it warmed up, and then was fine after that, although I had to run the lash a little looser than recommended.
