Originally Posted by patrickt
FWIW, ERA uses a Dayton 3LCH7. Two wires, easy to control via temp sensor in the lower radiator hose, toggle switch on the dash, or both.
Thanks patrickt. The 3LCH7 is the motor I currently have. I was able to locate the original Ford motors and determine that the different speeds for the Mustang are controlled thru a resistor, so wiring will be the same as the 3LCH7. The search for originality is always fun.
