Old 06-12-2002, 05:18 PM
Joe Prochazka Joe Prochazka is offline
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
Default YEP
Zderf is right---
the adapter goes on the block with the oil pressure sender fitting towards the front of the block.
The bottom hole is the output to the filter.
The top hole is the return back into the engine from the filter.
Also, I too noticed that the adapter did not match the gasket.....about 5 minutes work with a
Dremel tool took care of that. Reinstalled and started the engine and had 70 lbs of oil pressure. whoopee!
Thanks to all that responded to this post.....this place is the best.
