05-20-2020, 10:18 AM
AR
Panicky - clutch pedal set screw
Patrick - at your suggestion I finally got around to checking the left side clutch pedal shaft boss set screw and it was a bit loose and needed some tightening (1-1/2 to 2 turns. Mine (#782) however has a cap screw that goes all the way through the shaft and both walls of the boss which would seem unlikely to come completely out. For some reason I thought I remember it was a point bearing set screw on your car that you had trouble with It coming disengaged - or am I mistaken?
