05-30-2020, 11:10 AM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Next up is the fabrication of the crank/damper spacer. It will go on a lathe to accommodate the crank trigger wheel to keep it behind the damper (out of site). We are asking Jones Racing to custom build a pully setup for an FE. We will need to fab up a Alt bracket to mount the Denso sytle alternator down low to keep it out of the way of the plumbing required for the cross ram... the alt bracket in the photo is made from cork board material to get a template for the CAD guy.
