Rocket Sunburst wheels
As I make progress on my scratch build independent rear suspension, I am considering using the Rocket Sunburst wheels on the irs setup.
As you may have seen in some of my previous posts I already have a set of original Sunburst wheels on my car.
Why the Rocket Sunburst wheels? Well, my irs setup employs a Corvette C3 diff and GM hubs in custom Cobra uprights so I'm on a 5 x 4.75 inch wheel bolt circle.
I know a couple of you have used Rocket Sunburst wheels on your cars, Alfa02 (Tom) and Davereeves.
I would like to know if either of you have good pics of the inside hub mounting surface/center bore and the outside center mounting bore (where Rocket mounts their faux knockoff) of the Rocket Sunburst wheel.
I am try to determine what steps I will have to take (if it can be done) to adapt the Rocket Sunburst wheels to a Trigo knockoff hub.
Hope you two or maybe others can help with pics.
I'm also going to contact Rocket to see if they can provide pics as all their ad pics only show the front of the wheel with a center cap mounteed.
Thanks
Greg
