Old 06-07-2020, 01:58 PM
Mattsvtcobra Mattsvtcobra is offline
Cobra Make, Engine: Backdraft #360
Originally Posted by spdbrake View Post
That top small line the overflow line to the overflow tank. The nipple on the radiator is most likely cracked. If you pull the fan shroud (6 screws) and fan assy + 1 connector, then take off the large radiator hose. Loosen both clamps and slide it aft on the s/steel pipe.
You should have access then.
Thanks for the links!
