Old 06-10-2020, 01:02 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
As mentioned earlier shoulder harnesses should be mounted at essentially shoulder height. Anything lower and the forward motion also causes downward pressure from the harnesses causing you to slide forward and down (at best) and spinal compression at worst.
Tony
CSX4005LA
