Old 06-11-2020, 01:45 PM
Hall1836 Hall1836 is offline
Cobra Make, Engine: Superformance 351/427 stroker
Default update II
SO...thought I could live with a little shimmy. NOT! After having the tires balanced five times, by three different shops all with Hunter equipment and the last three done on Hunter Elite Road Force machines, the shimmy is finally gone. I had asked repeatedly if we could break down the mounted tires and start fresh, was told that was not necessary that the machine would tell them when to dismount the tire and rotate it on the rim. Well, apparently while adding another weight the machine said no good and they had to rotate the tire on the rim to balance it! No SHIMMY!
