Old 06-12-2020, 04:54 AM
1795's Avatar
1795 1795 is offline
Glen,
I just remembered something. Check your side to side clearances for the headers. I could not install my engine with the headers attached, as there was not enough room. But I also could not get the headers in after the engine was installed, not enough room from the top or bottom. I had to place the headers in first at their respective sides out of the way, and then pull them up for install after the engine was secure on the mounts. Each car is different, you may not have a problem with this, but it is better to check clearances first than to find out half way through that you need to pull the engine back out.
Jim
