Yes mate, engine and gearbox together.
Raised the car as you can see to get my fat gut under to line stuff up and bolt cross member in. With the TKO600, had to drop the assembly a bit to get the gear stick under the tunnel enough to slide back to go up through the hole in the tunnel.
As for taking the body off, very easy as it only weighs 48kg.. The daughter and I managed easily.
289 FIA Cobras RULE!
