[quote=spdbrake;1478040]
I see you have the dual 10" fans. If you want to do an upgrade the Mishimoto Raceline 10" fans push 1600 each and are pretty much plug and play. (drill new mounting holes in the shroud). I'm rock steady in traffic above 100F summer days]
I was doing a little clean up work and was working on another leak I found at the water inlet. I pulled it off and found a 160* thermostat (I don't hate it, since I am in FL) and replaced it with another 160* since I was in there. It stays at 90*c with the dash light on and off. 90*c turns into 194*f.
I assume the light going on and off in traffic is normal? I have not attempted to just leave the fan on while in traffic or stopped.
