Old 06-21-2020, 12:53 PM
DesertMK4's Avatar
DesertMK4 DesertMK4 is offline
Cobra Make, Engine: FFR 306 Ford Racing Holley carb.
The most effective way to soften the ride is to soften the springs. Shocks only dampen the motion. Sway bars only increase the spring rate when cornering. I dropped the spring rate from 550 to 450 front. I dropped rear by 100 lbs as well. Just doing the front did not solve the seat of pants feel. I tried a 50 lbs. drop, but it wasn't enough. Tire pressure will help a little. Rubber bushings a very little. Sway bar diameter none. Softer compression setting on shocks some. Shocks rebound very little. Tire aspect ratio some. My 2 cents worth.
