Old 06-21-2020, 11:32 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Morris View Post
Seems to me that if you have the one wire alternator...you could take a jumper off the alternator and go to one side of a lamp.....then on the other side of the lamp...connect to the battery......that way when you turned the ignition on you would see the lamp on from one side being hot ...then when the alternator started spinning and had a output the light would go off because you would have a 12 volt potential on both sides of the lamp....if the alternator started going bad the the battery side would be hot and the alternator side would be ground so the lamp would light.......I think ��
Yes, that should work.
A bulb in parallel with the heavy lead, would show up any voltage difference, so brightest at ignition on, 12v + on one side, and 0 volts at the alternator.
The bulb would present virtually no circuit path while in parallel with near 0 ohms of the heavy charging wire.
Gary
