Old 06-29-2020, 05:10 AM
Moritz55's Avatar
Moritz55 Moritz55 is offline
Cobra Make, Engine: Superformance, '65 427/MKIII with Roush V8 - 351W w/770cfm 4BBL Holley, 514hp
I realize this is an older thread, however I did want to share with you all that I decided to add the Ron Francis LS-11 low voltage sensor. Even though it triggers at 11V , which I know is low ...
Website: LS-11 Lo Voltage Sensor-Ron Francis Wiring
Background:
I have a 1wire Alternator/No Voltage Regulator in ... SPO2454 so the Red Warning light is Non-functioning as-is in the dash.
My rationale is:
1) My Headlights are wired "ON" during normal driving which puts a constant load, around 5-6amps on my system during driving/ignition switch ON.
2) I turn my cooling fans on at around 90C (rather than let the auto sensor at 100C turn them on). I believe they draw close to 20amps..
I felt these loads would definitely accelerate draining my battery quickly if my alternate fails...
My hook up of the LS-11 was pretty easy. There is an Extra Switched Ignition HOT line that I used off the fuse box. For the GND I used the chassis where the 12V cigarette lighter/auxiliary port is.
Anyway .. just wanted to share my logic..
Many thanks...
Many thanks,
Mark
Superformance: SPO2454 , Titanium w/Black Stripes
Engine: Roush 427SR w/770cfm 4-Barrel Holley
Transmission: Tremec TKO-600
