Old 07-06-2020, 03:32 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by SBSerpent View Post
Ok, so pardon my ignorance on this topic, but what I'm hearing is that since I do not and never intend on racing this car, I can get by with just a standard oil pan and ditch the high capacity, low clearance pan???
> Absolutely. You should also be using a standard pressure,
> standard volume pump.
Music to my ears! A life without cringing every time I approach a speed bump!
Couple of other questions. My current pan has a threaded hole for the temp sensor on the DS of the pan and a fitting to accommodate the dipstick at the top of the pan on the PS. I didn't see any of these features on the Kevko pan. Hmmm. Recommendations?
> Most 351's have the dipstick in the front cover, on the right side
> Check yours to see if the hole has been plugged.
Also, will I need to change the pick up with a standard pan?
> Yes. Always buy the pick up to match the pan.
Sometime after this picture, I drilled and tapped this hole for a NPT fitting. Then I used a Lokar flexible dipstick. It looked better, and never leaked.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
